What transformers would I need to use to reference as the cell rotation angle in the dgnstyler?
  • Jan 12, 2016 5:27 PM UTC
  • 5 replies
  • 108 views
gmbutler2
Forum|alt.badge.img+10
I am using an aggregated object to insert a cell using the dgnstyler. The aggregated object has 2 geometries, a point and a line. I need to use the line as a reference for the angle of the cell rotation, but I do not know how to derive an angle for this line. Can someone help me find a way to do this?
Best answer by fmelizard
This one was too interesting. I had to bite. I must ask, where is that original geometry coming from? Smallworld perchance?
In any case, given that you're starting with an aggregate and you want to end with a point and a rotation, it raises an interesting problem. How do you split things up, keeping what you need handy, without resorting to some kind of evil FeatureMerger, which will block things up, downstream.
I realized that you can tuck away the original geometry conveniently with a GeometryExtractor, and then Deaggregate followed by a GeometryFilter to keep only the piece you need. Then extract what you need from it, and then you can put back the whole original geometry with a GeometryReplacer, and then repeat but the second time keep the other piece. Works great. No blocking. Just some features being Deaggregated and destroyed 'cause they're unwanted a couple of times.
Never had done this trick before. Worked great. Plus it was a great test of the FME 2016 release candidate we're fussing about these days.
Screen shot below, FME 2016 workspace attached - pointlinerotationcalculator.fmw
The technique should work with FME 2015 as well, but some of the transformers may be a bit differently named so you'd need to recreate those parts if you tried to open this workspace with an older FME. (Generally not recommended).
Good luck.
erik_jan
Forum|alt.badge.img+26
  • Jan 12, 2016 5:57 PM UTC
The AzimuthCalculator will get you Angle and Azimuth of a line. This transformer can be downloaded from the FME store.
fmelizard
Forum|alt.badge.img+22
  • Jan 13, 2016 6:31 AM UTC
Good luck.
fmelizard
  • Jan 13, 2016 6:32 AM UTC
Good luck.
Click on the .png link above (or here) to see the workspace more clearly.
gmbutler2
  • Mar 29, 2017 4:28 PM UTC
Wow I never was notified that this was replied to lol. I have learned quite a bit since then. Thanks @daleatsafe. Yes it was from smallworld. What I do now is I run a deaagregator followed by a geometryfilter. I run the line through a length calculator and into a featuremerger to bring that length attribute into the point. Then I run it through an reprojectanglecalculator to get the proper reprojected angle for my cell rotation. Easy-Peasy! :)
fmelizard
  • Mar 31, 2017 4:30 AM UTC
Hey, thanks for responding. I like the sound of your solution too.If the data volumes are modest bringing the parts together via a FeatureMerger is a completely good idea. Well done!
