Timeout / Postgis-Writer
  • Mar 23, 2017 2:26 PM UTC
  • 5 replies
  • 52 views
Hi ,
is it possible to set a timeout-Parameter for writing in a Postgis-DB to ensure, that the connection will be closed.
  • Mar 23, 2017 3:45 PM UTC
I don't think that's possible.
itay
Forum|alt.badge.img+19
  • Mar 23, 2017 4:32 PM UTC
suspected as much, wont it automatically be closed when the writting is ended?
  • Mar 24, 2017 6:14 AM UTC
yes, connction closed when writing ended. But if there is a problem at the postgis-db during writing, the connection will not be closed.
itay
  • Mar 24, 2017 8:26 AM UTC
Makes sense since then the writing will try to continue.
  • Mar 24, 2017 8:40 AM UTC
I understand, but it would be great, if I can define a timeout, so the connection closed if there is no activity for a long time.
Because if I want to run skripts on the Postgsi-db to repair the table. The Skript didn't start, because there are still connections open.
