I have a large KML file that I would like to split into several smaller equal size KML. My original KML file has 311,055 polygon records and is too large to open in Google Earth as is. I would like to create several sub files from this file (e.g. 5 KML files with 62,211 records each).
Split single KML into multiple KML files with equal record count
Best answer by todd_davis
Pass all features through ModuloCounter with Count Maximum set as 5. Then set "_modulo_count" as the fanout on the KML writer (e.g. @Value(_modulo_count).kmz ). You will get 5 output kmz called 0.kmz, 1.kmz, 2.kmz, 3.kmz, 4.kmz.
