Shp attributes as input to raster mosaicker
  • Oct 3, 2017 3:42 PM UTC
  • 106 views
I have a shp of a tile grid and a folder than contains thousands of tif's. Each grid square in the shp has an attribute that contains the name of it's corresponding tif. How can I use this attribute to only select it's corresponding tif in the folder to either:
1. copy the tif to a new folder (file copy writer)
or
2. use as input to the raster mosaicker
I can concatenate a string to build up the full path of the tif in the folder. Do I pass this list to what?
Best answer by jdh
Set the Dataset parameter of the FeatureReader to an attribute containing the full path of the tif to read in.
Set your Output port to Single Output
This will work with multiple tiffs.
Although theoretically the tif or geotiff would have a specific feature type and corresponding output port, the interface is a little quirky when you point the dataset to an attribute instead of hardcoding, and it's generally easier to just use the generic port, particularly for rasters which don't tend to have attributes.
Hi @mddown
if you can concatenate the full TIFF file name you can then:
  • pass it to FeatureReader as Dataset parameter value to read the required source TIFF OR
  • add filecopy_source_dataset attribute to the Shape feature and pass it to File Copy Writer to make a copy of the file (NB: File Copy Writer also understands filecopy_dest_filename) OR
  • add RasterMosaicker after the FeatureReader to mosaic the rasters.
  • Oct 4, 2017 6:05 PM UTC
Hi @mddown
If I pass it to a FeatureReader could that handle multiple tiff's or just 1 tiff?
  • Oct 4, 2017 6:06 PM UTC
@LenaAtSafe
If I pass it to a FeatureReader could that handle multiple tiff's or just 1 tiff? I've only been able to get it working with 1 tif.
jdh
Forum|alt.badge.img+41
  • Oct 4, 2017 7:11 PM UTC
