Raster with 1 channel and 3 values as palettes - strange!
  • Nov 21, 2022 9:06 PM UTC
  • 152 views
sigtill
Forum|alt.badge.img+25
I`m trying to make a strange raster, due to a specific software demanding exactly that format.
It seems to be a GeoTIFF with 1 rasterband (UINT8) that has palettes with 3 values (RGB). See below for more information. I have managed to create the 1 channel TIF with the correct value, however I struggle to add the palette, and add the correct value for each palette to each pixel.
Since FME can read the file correctly, I assume it can also create such a file, however I am stuck after examining all the RasterPalette* Transformers.
Any raster-wizards out there?
Best answer by daveatsafe
Hi @Sigbjørn Herstad​,
If you have a standard three band RGB image, the RasterPaletteGenerator will convert it into a 1 band image with an optimized RGB palette. This is normally the easiest method to use. If you just have the one band index raster, you can convert this to a palette using the RasterPaletteAdder. You will need to create an attribute containing the text of the palette definition first. For more information, please see the documentation for the RasterPaletteAdder.
daveatsafe
Forum|alt.badge.img+24
  • Nov 21, 2022 10:15 PM UTC
sigtill
  • Nov 22, 2022 9:44 AM UTC
Works like a charm. I ended up using the RasterPaletteExtractor on the sample file I had, to see the structure of the _palette property. And then I hand-write this and attached to my own data. Great! Thanks! Thought I knew everything about rasters, but this was a new one after 10 years!
sigtill
  • Nov 22, 2022 12:35 PM UTC
I also see you can add multiple palettes. This is nice if you want multiple fields, for instance color and value and text and height etc. However when I try to write this to TIF I just get the error:
"GEOTIFF writer: Unsupported palette value interpretation 'STRING'. Please convert the interpretation to one of the following valid types: RGB24. This can be done with the RasterPaletteInterpretationCoercer transformer".
Are there any formats that do support multiple Palettes on single bands?
