If i have an outline of the UK and coordinates dotted around the UK represented as points, is it possible to create polygons which 'colour in' the UK based on the closest point? and if so, what approach should I be taking?
  • Apr 14, 2023 11:36 AM UTC
  • 70 views
Ultimately, i aim to end up with a map where you know depending on your location, where your nearest point is, represented by area.
Best answer by redgeographics
Yes, the VoronoiDiagrammer to generate the areas and then clip them with the outline. It just handles as-the-crow-flies situations so doesn't take in account roads and I'm also not sure what it does with islands.
Forum|alt.badge.img+63
  • Apr 14, 2023 12:13 PM UTC
This sounds like the exact answer im looking for, thankyou!
