I have two featureclasses in a geodatabase. These two FC are related with each other, 1st with Object ID and 'X' in 2nd featureclass. i want to update a field in 1st featureclass on the basis of 2nd FC, after it is joined.
  • Aug 20, 2014 10:21 AM UTC
  • 48 views
  • Aug 24, 2014 6:28 PM UTC
HiYa,
You should take a look at the AttributeValueMapper
This will populate an attribute with any value(s) based upon the value from a source attribute.
It's a bit like running a Tester with an AttributeCreator straight after it
ie you test for a value and then populate an attribute
Hope this helps
Howard L'
  • Aug 25, 2014 10:19 AM UTC
Hi Howard,
Thanks for the reply! it didnt help. I want to query a feature from a featureclass for each object id value of another featureclass and update a field on that basis!
I hope i am bit clearer now.
Tester doesnt actually query, it instead wonks on single featureclass/table. neither attributevvaluemappper helped!
  • Aug 27, 2014 5:03 PM UTC
Not really much clearer !
If you could add some screen dumps or sample data it might help
You need to use the joiner or feature merger first.
H'
