How to overrule GeoPDF coordinatesytems
  • Dec 10, 2020 6:25 PM UTC
  • 55 views
meijer
Forum|alt.badge.img+3
The next screenshot is reading a corrupt geospatialPDF.
Result: It gets the page points, at the well known zero-island. The extent shows the points (~pixels if you like) of the original pdf. 595x842pt
CaptureI know the coordinate system. LL84. Therefore I could overrule the coordinate system. But what happens is that the reader thinks there is no coordinate system. Therefore everything is considered page-points(595x842) And these coordinates are treated as lat,lngs. Projecting this geometry all over the ("edges" of the) world
CaptureThe settings of the reader:
The behavior of the first option would be in my mind.
Geospatial (if possible or over ruled).
 CaptureIs this a known limit and is there a way to read such document anyways with the right coordinates?
debbiatsafe
Forum|alt.badge.img+24
Hi @meijer​
Unfortunately, the documentation notes that:
For content objects within a geospatial map frame, the reader will produce features with geospatial coordinates and coordinate system. If no map frames exists, or if a content object is not within any map frame, then features will be produced with coordinate in page points.
It seems like the features were not written within a map frame if you are getting features in page points when read in FME. You could try using a CoordinateSystemSetter, then offsetting/scaling if you know the area where the features are located but your coordinates will very likely not be in the correct location.
meijer
  • Dec 11, 2020 9:03 AM UTC
Hi Debbi,
Thank you for your answer. I added the coordinate system that I can read from the geoPDF.
It seems that there is a map extent, but one that FME cannot read/recognize. (I guess the datum is unknown?)
It is good to know that QGIS can read the PDF without any problems
PROJCRS["Transverse_Mercator",
  BASEGEOGCRS["GCS_GRS 1980(IUGG, 1980)",
    DATUM["D_unknown",
      ELLIPSOID["GRS80",6378137,298.257222101,
        LENGTHUNIT["metre",1,
          ID["EPSG",9001]]]],
    PRIMEM["Greenwich",0,
      ANGLEUNIT["Degree",0.0174532925199433]]],
  CONVERSION["unnamed",
    METHOD["Transverse Mercator",
