How to create disjoint boundaries of disjoint cluster from las?
  • Mar 3, 2020 9:59 PM UTC
  • 73 views
arthy
Forum|alt.badge.img+8
Hello,
I have las file in which some points after some manipulation produce separate cluster of points as shown on the image.
How could I produce separate boundaries for each cluster?
owen
  • Mar 4, 2020 2:27 PM UTC
You can use the NumericRasterizer then RasterExtentsCoercer (set to data extents) to produce a footprint polygon for a point cloud. The correct raster cell size is key to getting a good shape
