How to create DEM from ERDAS IMAGINE(*.img) raster
  • Nov 19, 2014 6:58 AM UTC
  • 160 views
How to create DEM from ERDAS IMAGINE(*.img) raster?
  • Nov 20, 2014 2:17 PM UTC
A DEM isn't a format (well it is a format too), it's a type of data representing heights. Your IMG could already be a DEM, in which case I think just use a IMG reader and whatever-format writer (.dem is for USA only I think). .asc is popular for DEMs.
  • Nov 21, 2014 3:58 AM UTC
Here I need DEM in XYZ format....
  • Nov 21, 2014 5:09 AM UTC
Hi Bino,
This procedure could be a possible way.
ERDAS reader
=> RasterCellCoercer
Output Cell Geometry: Points
Extract Band Values: Z Values
=> PointCloudCombiner
=> POINTCLOUDXYZ writer
If the input raster has palette(s), you will have to remove the palette(s) with the RasterPaletteRemover before the RasterCellCoercer.
And also, if the raster has multiple bands, you can remove unnecessary band(s) with the RasterSelector+RasterBandRemover beforehand.
Takashi
