How do I merge contours from Contour generator or Shape file onto a Geotiff?
  • Nov 22, 2019 12:31 AM UTC
  • 82 views
I'm having trouble combining contours onto a geotiff raster prior to draping. Can anyone help me to find a process to get the contours onto the Geotiff, preferably with labels on the contours.
I've tried the contour generator and a shape file but having real difficulty projecting the contour data onto the raster successfully.
Forum|alt.badge.img+63
The easiest way would be to use the VectorOnRasterOverlayer or MapnikRasterizer. For the VectorOnRasterOverlayer you'll need to use a FeatureColorSetter first to specify a color for the contour lines, the MapnikRasterizer allows you to do that in its own properties.
