geotiff to tab
  • Dec 22, 2017 1:05 PM UTC
  • 141 views
Best answer by davideagle
Use a Reprojector transformer and when you write to either a Tiff or GeoTiff format, make sure that on the writer's parameters you check the box to generate *.Tab files. Incidentally you can also generate *.tfw world files if needed as if MapInfo sees these it will auto generated the *.tab files itself.
debbiatsafe
Forum|alt.badge.img+24
Hi @farmangr
Would it be possible for you to provide more information regarding your question? Are you looking for information on how to translate GeoTIFF to tab?
Kind regards,
Debbi
danilo_fme
Forum|alt.badge.img+58
  • Dec 22, 2017 11:17 PM UTC
Hi @farmangr,
I agree with @DebbiAtSafe :)
  • Dec 23, 2017 7:35 PM UTC
Hi@danilo_fme
Project GeoTIFF translate into the projection tab for Mapinfo
davideagle
Forum|alt.badge.img+21
  • Dec 25, 2017 12:16 AM UTC
