Geotiff band offset and scaling
  • Mar 27, 2024 5:05 PM UTC
  • 0 replies
  • 147 views
jdh
Forum|alt.badge.img+41
I’m reading a geotiff file with embedded scaling and offset,  snippet from gdalinfo:
Band 1 Block=1024x1024 Type=Byte, ColorInterp=Red
  NoData Value=255
  Overviews: 6000x6000, 3000x3000, 1500x1500, 750x750
  Offset: -1,   Scale:0.008
Band 2 Block=1024x1024 Type=Byte, ColorInterp=Green
  NoData Value=255
Band 3 Block=1024x1024 Type=Byte, ColorInterp=Blue
  NoData Value=255
When working with the data in FME just the the 8-bit value is shown (0-255) when I was expecting values between -1 and 1.   In my particular use case the scaling is constant and I can just apply a correction, but I was wondering if there is a setting I’m missing to have FME apply the scaling/offset automatically.
