convert ESRI shp polygon to INSPIRE gml
  • Jan 18, 2019 3:05 PM UTC
  • 62 views
. The data contains englands ceremonies as polygons. After converting the shp according to this demo https://knowledge.safe.com/articles/775/inspire-gml-basic-writing-example.html only a few polygons get the geometry attributes.
fme_geometry (string) fme_aggregate
fme_type (string) fme_area
xml_type (string) xml_area
Most of the polygons get these kind of geometry attributes
fme_geometry (string) fme_undefined
fme_type (string) fme_no_geom
xml_type (string) xml_no_geom
This is my project.
Kind regards
Nico
jovitaatsafe
Forum|alt.badge.img+11
Hi @user789456,
I took a look at your workspace and it looks like you're using the GML writer instead of the INSPIRE GML writer, would you be able to swap that out and see if that works for you? I wasn't able to test successfully as it doesn't seem like I have access to the xsd schema file in the writer. As well, I'm not entirely sure that you need two GeometryPropertySetters in your workspace (looking off of the tutorial workspace). I'd also suggest setting your writer to Validate Output File. That way it will catch any errors for you and guide you to where the issues are. Hope that helps a bit!
I'm having trouble downloading your file if you wouldn't mind uploading your template workspace again and attaching the xsd file in case anyone else in the community is able to give you some more suggestions.
