Build polygon from 2 layers
  • Nov 28, 2018 10:25 PM UTC
  • 13 replies
  • 142 views
mr_fme
Forum|alt.badge.img+9
I've attached () a DWG file, which have 2 layers, I need to create / close polygons using the TRAIL layer, however the TRAIL layer in some sections cross with NETWORK, and so the polygon is not created. How can I create a polygon from the moment that TRAIL touches the first line NETWORK? See the images below:
Thank you
Best answer by gio
@mr_fme
Hi.
Here is a screen of the workspace doing it.
I must say I wasted some time to find your topology of the trail is not solid.
That is why there is a snapper with a 1m range(!)
I'll try upload (if it gets past the firewall here.mrfme_forum.fmw
In case fileupload fails, here is a screen.
result:
gio
Forum|alt.badge.img+15
  • Nov 29, 2018 12:41 PM UTC
@mr_fme
Hi.
result:
gio
  • Nov 29, 2018 12:46 PM UTC
the workspace upload fails.
It seems the full path is inserted. My file location h:\\documents\\my..etc. is inserted?? see fmw link.
mr_fme
  • Nov 29, 2018 1:27 PM UTC
@mr_fme
Hi.
result:
Hi @gio,
Your result was fantastic, that's exactly what I need!!. But I'm in trouble ... it was not possible to download your workspace unfortunately. I used the image you sent to build the workspace, my Intersector transformer is not generating the correct number of features, see also the final result.
Could you help me?
Thank´s
gio
  • Nov 29, 2018 1:33 PM UTC
@mr_fme
You should be able to upload your workspace, yes?
Seem like the LineExtender is not giving sufficient objects. But I can't see it.
Do you have the outside port on the bottom clipper ?
I am assuming you are using same data as you posted of course.
gio
  • Nov 29, 2018 1:41 PM UTC
@mr_fme
HI.
I have the bottom Clipper set to not generate aggregates. (they standardly do; something I often forget..)
That might account for the difference.
mr_fme
  • Nov 29, 2018 1:47 PM UTC
@mr_fme
HI.
@gio
Follow my template teste_safe.fmwt
mr_fme
  • Nov 29, 2018 2:12 PM UTC
@mr_fme
@gio
The LineExtender is giving the same objects from your image. I´m using the same data as posted.
Thank´s
mr_fme
  • Nov 29, 2018 2:14 PM UTC
@mr_fme
outside port from bottom clipper
gio
  • Nov 29, 2018 2:39 PM UTC
@mr_fme
The top clipper should have Clippees on boundary = treat as outside.
If I change that inyour workbench, it works as intended.
mr_fme
@mr_fme
Hi.
result:
Hi, @gio
I was able to download your workspace. And solved my problem. Thank you very much
mr_fme
  • Nov 30, 2018 11:53 PM UTC
It seems the full path is inserted. My file location h:\documents\my..etc. is inserted?? see fmw link.
Hi @gio and others,
Now I need to do the same thing I did with network to cut, but also using park, I inserted the park layer and the following error appears:
INDEX FAILURE - requested predicate not implemented
I need help
follows my workspace: clip_areas.fmwt
gio
  • Dec 3, 2018 1:49 PM UTC
@mr_fme
first:clip_areas.fmw
The index-failure is caused by the identical geometrical objects, as pointed out by @takashi. In this set you have the hatches as well as the polygons. (somehow the recent dissolver is sensitive about identity..;)
Filter out the hatches before dissolving.
Here is the adapted workspace to add parks. Hope you can upload.
Result
mr_fme
  • Dec 3, 2018 2:27 PM UTC
@mr_fme
Result
Hi @gio,
Very good, you help a lot.
Thank you very much
