Automating WFS download
  • Feb 21, 2018 1:09 PM UTC
  • 169 views
pflegpet
Forum|alt.badge.img+8
I would like to create a workflow to download and merge vector data from a WFS. The city of Vienna provides building footprints in shape format via WFS. Due to the large filesize it is recommended to reduce one download to a tile of 2x2 kilometers or smaller. As I need the complete dataset I try to create a workspace to download all tiles with getfeature requests (e.g. https://data.wien.gv.at/daten/geo?service=WFS&version;=1.0.0&request;=GetFeature&typeName;=ogdwien:FMZKGEBOGD&outputFormat;=shape-zip&SRS;=EPSG:31256&BBOX;=2748,341794,4516,343209) and then merge the tiles into a File GDB. Is it possible to dynamically create the request by inserting the necessary bounding box coordinates and then merge data directly out of a ZIP file. Thanks for any help.
Best answer by redgeographics
If you use the FeatureReader with tiles as input you don't need to worry about inserting coordinates into the request.
The FeatureReader is set up like this:
Note that the max features setting does apply, so make sure you set it high enough (I tried a 2 x 2 km section near the Hofburg and that yields only 11000 buildings, in tests I've put that parameter as high up as 200000 without maxing out).
The Spatial Filter setting of Envelope Intersects will automatically apply the bounding box of the Initiator to the request.
Forum|alt.badge.img+63
pflegpet
  • Feb 21, 2018 2:20 PM UTC
Awesome, thank you for your detailed answer. Would you mind sharing the workspace? I could use some help setting up the creator as I never used it before.
Here you go: none2none.fmw
pflegpet
  • Feb 21, 2018 2:26 PM UTC
Thank you! You just safed me a lot of time.
