Appearance Styler only working for jpeg
  • Apr 18, 2017 1:44 AM UTC
  • 39 views
I have successfully managed to add a jpg to a TIN surface using a jpeg, appearance styler and appearance adder. When I swap in a png, with the same extent, (perhaps any image with transparency?) it no longer works. I get a black surface, or sometimes a silver one.
  • Apr 18, 2017 2:40 AM UTC
I should say I am viewing the result in a 3D PDF which should allow for 3 bands and an alpha band. The png is showing all black in Inspector but shows normally in an image viewer.
Forum|alt.badge.img+63
I seem to recall some problems with PDF handling transparent rasters, so your PNG may indeed suffer from that.
