Unable to use FeatureMerger on different geometries
  • Apr 30, 2018 1:10 PM UTC
  • 6 replies
  • 116 views
lianaolianov
Forum|alt.badge.img+5
Hello,
I have two set of data (Points and lines).
They have a common attribute X
Some of points have a common attribute value (X) with lines
How do i can extract those lines ? I tried the feature merger but the translation fails
Thank you.
Best answer by jneujens
If you know this attribute X --> a simple TestFilter on the lines will suffice?
But the FeatureMerger should also solve your problem! What are your settings in the transformer?
erik_jan
Forum|alt.badge.img+26
  • Apr 30, 2018 1:14 PM UTC
For the points/lines with common attributes, you can use the Aggregator (group by common attribute).
Another option would be the NeighborFinder (max distance = 0).
Or the PointOnLineOverlayer.
So many options to choose from.
jneujens
  • Apr 30, 2018 1:22 PM UTC
lianaolianov
  • Apr 30, 2018 1:39 PM UTC
Hello,
How can I do it with just the tester ?
Here is my workspace file
Thank you
hydrographic-4quadrant-splitter.fmw
lianaolianov
  • Apr 30, 2018 1:51 PM UTC
Hello,
The aggregator will not filter lines having same value of the attribute X as entering points.
For the NeighborFinder and the PointOnLineOverlayer I don't know how can I use them
erik_jan
  • Apr 30, 2018 2:33 PM UTC
Hello,
Using PointOnLineOverlayer: The output port Line will contain all lines, with an additional attribute _overlaps, containing the number of points that are on the line.
Testing for _overlaps > 0 will get you all lines, that overlap with at least one point.
The attributes of the point will be added to the line.
jneujens
  • May 2, 2018 10:33 AM UTC
Hello,
Thank you
I only have FME 2017.1, so I cannot really open your whole workspace.
If you know that attribute X has value '1' for both points and lines, you can just send the lines through a TestFilter. All the lines with attribute X = '1' can be seperated for example.
