Randomly split polygon into n subdivision
  • Sep 11, 2015 1:56 PM UTC
  • 88 views
I have to create sample dataset of one region subdivided into sub-regions. I wonder if there is a way to randomly split polygon inputs to create simple sub-divisions. The number of sub-divisions could vary between 10 to 20.
I was thinking about randomly select two coordinates of the input polygon, create a line and split the polygon by this line, but not sure if its a good approach.
Any suggestions?
Thank you a lot,
Max Demars
  • Apr 12, 2018 6:03 PM UTC
@burton449 I was wondering if you were ever able to find a solution to this problem.
I'm running into something similar. Thanks!
danilo_fme
Forum|alt.badge.img+58
  • Apr 15, 2018 11:34 PM UTC
Hi @burton449,
If you want to select a area in the Reader file using for example a Bounding Box, you can use the option Search Envelope: Navigator -> Reader -> Parameters ->Search Envelope:
Thanks,
Danilo
