_job_failure_type
  • Sep 27, 2018 5:51 PM UTC
  • 44 views
The previous versions of the FMEServerJobSubmitter returned an attribute upon failure named _job_failure_type. This attribute value is missing in the latest FMEServerJobSubmitter. Is there any replacement for it?
HI @jimo,
I believe there should be a _failure_reason output and this would be the closest replacement for _job_failure_type. If the job has failed the _status attribute will also be set (it would return a value like FME_FAILURE or JOB_FAILURE) and you can refer to the _statusMessage attribute which will provide more information on what caused the job to fail.
There is an internal request in place to fix this in the documentation.
  • Sep 28, 2018 5:31 PM UTC
HI @jimo,
I've upgraded to version 3 of FMEServerJobSubmitter and don't see _job_failure_type in the Failed attributes
