Custom transformer and Dynamic schema
  • Sep 19, 2013 3:25 PM UTC
  • 7 replies
  • 90 views
Hi guys -
I am still having an issue with my Dynamic Schema workbench working correctly with polygons.  I have finally worked out it is not the workbench itself that has the problem, but my custom-built transformer.
The transformer is a reprojection transformer and when dealing with polygons it actually GeometryCoercer's the polygons into lines to do the projection, then converts them back to polygons.  I believe that this is why when I run my Dynamic Schema workbench on a shapefile polygon, it comes up with the "Features with no schema defined" error.
My question is - is there a way to get the Dynamic Schema function to work, without altering the transformer??  How do I get FME to remember the schema of the polygons before they went through the transformer??
Thankyou
fmelizard
Forum|alt.badge.img+22
  • Sep 19, 2013 5:49 PM UTC
I am not sure about it since I dont know the exact working of your ws, but you can try to add a readear as a ws resource and use it to define the schema.
Itay
  • Sep 20, 2013 3:19 PM UTC
I cannot reproduce such a situation. My test workspace works fine for all of point, polyline, polygon features.
One possible reason for the error is that fme_featrure_type has been changed. Does your workspace change fme_feature_type only when the feature is polygon?
Takashi
fmelizard
  • Sep 20, 2013 6:14 PM UTC
Normally this works with all geometry types, so somewhere in your costum transformer, the 'link' is lost with the original schema (as Takashi suggests).
  • Sep 23, 2013 8:00 AM UTC
Ok thanks for your replies.  I guess I have to try and repair the link!  But one thing that has me very confused right now is the exact meanings and differences of the following terms:
fme_feature_type
fme_geometry
fme_type
Schema
I don't understand the differences between them....
Thanks,
  • Sep 23, 2013 8:32 AM UTC
Oh and in regards to FME_Feature_Type - I noticed that when I ran the workspace Statically rather than Dynamically, and added a text attribute to my writer that linked to the fme_feature_type attribute, the output file for a polygon shapefile had the field empty, but in the output file for a polyline shapefile, fme_feature_type was populated.
I am assuming this means that I am losing fme_feature_type in the custom transformer for polygons.  Is there a way to keep the link in a dynamic workspace without editing the transformer?  I've tried adding a "Reader as Resource" but this doesn't seem to work....
  • Sep 23, 2013 10:29 AM UTC
fme_feature_type will be usually kept unless it is changed or removed explicitely.
At first, you should find where fme_feature_type is lost. Then consider how to keep it. The Logger or / and the Inspector help you to specify the location in which fme_feature_type is lost.
If the location in the custom transformer, you will have to edit it.   See these links about several related terms: http://docs.safe.com/fme/html/FME_Transformers/Default.htm#geometry/fme_geometry.htm http://docs.safe.com/fme/html/FME_Transformers/Default.htm#geometry/fme_type.htm http://docs.safe.com/fme/html/FME_Transformers/Default.htm#geometry/fme_feature_type.htm http://docs.safe.com/fme/html/FME_Workbench/Default.htm#Understanding_Schema.htm   Takashi
  • Sep 23, 2013 3:27 PM UTC
Thanks Takashi,
