old workspace in new version
  • August 18, 2015
  • 25 views
I have a workspace whcih I would like to open in my FME 2015. The worksapce was made in an older version and comes out blank if i klick yes to continue in the warning pop up. How can i open my workspace?
/Caroline
Best answer by david_r
Hi
First, make sure that you try again using the very latest version of FME Desktop from Safe:
http://www.safe.com/support/support-resources/fme-downloads/
You can also open the .fmw file in a text editor and look for the line containing "LAST_SAVE_BUILD" which will tell you exactly which version of FME was used to save it:
You can download previous version of FME using this URL pattern:
http://www.safe.com/fme<year>
Example: http://www.safe.com/fme2013
If that doesn't work, consider sending your workspace to Safe support (https://knowledge.safe.com/knowledgeSubmitCase) for analysis.
David
  • August 18, 2015
Hi
David
