Unknown Failure or stalling out
  • Nov 18, 2024 3:19 PM UTC
  • 144 views
liamfez
Forum|alt.badge.img+44
My team has a workspace that has ran thousands of times before that has started failing in two different ways. The first failure does not actually trigger FME to fail, it stalls out on the ContourGenerator and does not move. Memory space, RAM, CPU usage, and GPU usage are all fine, none of them spike or max out. In fact RAM usage is quite low. Other times it will fail, at the same spot and give this error:
An error occurred. FME will attempt to obtain more information on the error, but this may cause the translation to be terminated
An error occurred. Here is the information that FME was able to find on the error
get_next_capacity, allocator's max size reached
I found this post from four years ago suggesting to just contact the support team. Any ideas before I do so, or is that still the recommended route to take?
Version is FME 2021.1.3.0 (20211002 - Build 21631 - WIN64)
I know this is an older build, I was told by my management that a new build would not fix any issues/make a difference and they did not want to allow an update. If you think a new build would be beneficial and anyone has evidence that I could bring to my management that would be helpful.
nielsgerrits
Forum|alt.badge.img+67
You can alsways submit a case. If you can reproduce the error with a smaller dataset, it is very useful to attach that. I would refer the older topic. If they know how to solve it, this is the fastest way on.
s.jager
Forum|alt.badge.img+27
  • Nov 18, 2024 3:46 PM UTC
I’d start by checking a couple of things:
  • Has anything changed in the data this workspace processes of late? Maybe size, complexity, type of geometry, number of vertices, that sort of thing?
  • Disk space. FME uses quite a lot of disk space when dealing with larger datasets, so maybe it is running out of that. I’ve seen unexplainable error messages where the solution was to stop all FME instances, clear FME_TEMP, then try again.
  • OS updates, changes, policies.
I’m saying this because the error message seems to point in the direction of space allocation, which runs out of room to do so. It could also have to do with a windows update, in a version that is a few years old, because the error message is coming from Boost.org, a C++ library for a bunch of things (including a container for geometry - so no surprise there, I guess). And from what I can see on Github, it seems to try and allocate more than is allowed/available/necessary, but that may also be caused by policies on windows (or your OS of choice) not allowing more than so much - which is why you wouldn’t see a spike when checking memory usage as a whole.
liamfez
  • Nov 18, 2024 5:06 PM UTC
The size changes frequently and I do not think larger datasets have been an issue in the past, though I have been testing this and looking into this as that was my first thought as well. So far, nothing out of the ordinary. There should be plenty of disk space on this machine, but maybe something is wrong with the policy like you said. There was a windows update recently, perhaps that had something to do with it.
I am submitting a help ticket and also working with our IT team, I will let you know what they come up with. Thanks
