increment a field for multiple file
  • Apr 17, 2019 8:50 PM UTC
  • 73 views
I try to increment a field start at 1 and finish at the end of the file. I use a counter and it's work fin with 1 file. But i have 38 file. I need to start at 1 for each file. Do you have any suggestion? Thanks
Best answer by erik_jan
Use the Counter, but group by the file name (fme_basename).
That would start a new counter per file.
The grouping is done by using the attribute value in the Counter Name:
erik_jan
Forum|alt.badge.img+26
  • Apr 17, 2019 9:16 PM UTC
  • Apr 17, 2019 10:33 PM UTC
Thank you Erick. It's work.
