How to extract Populated Places from Openstreetmap
  • May 24, 2021 3:49 PM UTC
  • 125 views
Hi
Hopping this is the correct forum
I'm trying to work out how to extract place names from OpenStreetMap
(.osm) files from geofabrik.de
For testing I picked Wales
Ultimately I will push into PostgreSQL / PostGIS database hopefully
without corrupting non English names
In the attached Workbench I used AttributeExposer to show everything this
was done using the cache
My first question how do I make that dynamic?
There will be some distinct attributes like
name, osm_id, is_in, wikidata etc
and some dynamic ones especially non English names
My Second question is
how do I group similar attributes together and merge into a JSON string
for instance alt_name:en, alt_name:fr, alt_name:* grouped into alt_name
json this with then be held as a jsonb database type
Similarly name: en, name:fr, name:* grouped into official_names json
I couldn't see how to do this using AttributeFilter or Tester
All other attributes not yet accounted for grouped into all_tags json string
I've done something similar in C# with dynamic data in that instance I used switch case to loop though all the attribute names Is there a way to do that in FME?
Off course if there is a better way to do this please share
chrisatsafe
Since you are altering the schema, you have a couple of options for making this schema:
1) Schema from a lookup table
2) Schema from Schema Feature/Multiple Sources
I'd highly recommend checking out the Dynamic Workflows article as it will walk through a couple examples that should help you achieve what you are looking for. Depending on which method you use, the SchemaSetter transformer might also come in handy.
For question 2, perhaps the BulkAttributeRenamer could come in handy for renaming and the JSONTemplater for formatting the JSON string.
