writing raster to postgis
  • May 11, 2015 11:26 AM UTC
  • 83 views
bubblebeb
I am trying to write raster data to a postgis database.
I have a postgis spatial database and want to load raster to it. So far I have a PostGIS Raster Writer and have created the database in Postgis. When I run it I get the error message below in the log file.
2015-05-11 12:08:18| 1.4| 0.1|ERROR |POSTGIS_RASTER writer: This format cannot support palettes. Consider removing or resolving palettes that are attached to the raster
Any ideas on how I can load raster into Postgis would be appreciated.
  • May 11, 2015 11:58 AM UTC
Hi
maybe try the RasterPaletteRemover? You might need to insert a RasterSelector first.
David
jdh
Forum|alt.badge.img+41
  • May 11, 2015 2:00 PM UTC
If the palette contains RGB values you can use the RasterPaletteResolver prior writing to postgis
