Writing compound polygon to Oracle
  • May 30, 2013 12:51 PM UTC
  • 8 replies
  • 211 views
Hello, is there any way how to write compound polygon (lines + arcs) to Oracle with FME? When i try to write this kind of geometry i always get "ORA-13347 Description:the coordinates defining an arc are not distinct". But arcs seems fine to me (no redundant points, distance between them is larger than oracle tolerance).   FME 2013 (Build 13261 - WIN64) WIN 7 64bit Oracle 11gR2   Thanks for any advice, David
Best answer by kim
The problem is with the top 2 polygons, both of which contain a tiny arc. These 2 tiny arcs have a start and end point which is pretty much the same, and I'm not sure Oracle will be able to make a distinction between them. I'd try to get rid of them if I were you.
  • May 30, 2013 1:04 PM UTC
could you send such a feature to the Logger and post it here so we can take a look?
If the arcs aren't too important to you, consider using the ArcStroker to make your life easier.
David
  • May 30, 2013 1:33 PM UTC
unfortunately it is important to retain arcs.
Log FFS is placed here: http://sdrv.ms/18yjYI6, thank you for help.
David
  • May 30, 2013 1:52 PM UTC
How about inspecting the features through the GeometryValidator transformer?
Takashi
  • May 30, 2013 1:56 PM UTC
I think Takashi might be on to something as I ran your FFS through the GeometryValidator and caught 2 self intersections, one of them on the polygon with two boundary arcs.
Let us know if it still doesn't work.
David
Forum|alt.badge.img+5
  • May 30, 2013 2:11 PM UTC
  • May 30, 2013 6:12 PM UTC
Thanks Kim, I overlooked this. I will try to solve this issue tomorrow in work.
Best regards David
  • May 31, 2013 5:50 AM UTC
You could also try lowering the tolerance value in user_sdo_geom_metadata, but I'm pretty sure such tiny arcs have no meaning and could be left out/removed.
  • Jun 4, 2013 8:02 AM UTC
Sorry for late response, i was busy. I have solved this issue by removing small arcs from polygons (thanks Kim). But, I had to do it using AutoCAD Map 3D (mapclean command). Is there any solution to do this with FME?. I tried to use GeometryValidator, but without succes (small arcs are still there).
David
