Write New Geodatabase every x features
  • Aug 20, 2019 2:38 PM UTC
  • 12 replies
  • 91 views
jacklonsdale
Forum|alt.badge.img+5
Hi all,
I have a set of 8000+ GML files that i wish to batch process into a geodatabase, i have found that putting them a workspace runner is effective but slows down massively past 50 GML files. Therefore, i want a way to write a new geodatabase file every 50 features, to reduce the 8000 GML files to 160 geodatabases to then combine afterwards.
Has anyone any ideas? Apart from a huge conditional value in attribute manager!
Cheers
Jack
  • Aug 20, 2019 2:51 PM UTC
Lots of possible solutions, but the easiest is perhaps to use the Grouper transformer from the FME Hub and use the _group_index as part of the dataset fanout.
itsmatt
Forum|alt.badge.img+48
  • Aug 20, 2019 2:55 PM UTC
I would suggest you take a look at the ModuloCounter combined with a path reader. You should be able to use the ModuloCounter to help create Groups (https://www.safe.com/blog/2016/12/parallel-processing-tips-evangelist159/ ). Combine it with the Aggregator to build an attribute containing the 50 filenames going into the WorkspaceRunner.
The result should be a WorkspaceRunner which runs 160 times each with 50 GML files as the source.
lars_de_vries
Forum|alt.badge.img+10
Did you know that...
The Grouper works great, but the GroupCounter works faster and does the same job?
  • Aug 20, 2019 3:32 PM UTC
I did not! Thanks Lars :-)
lars_de_vries
Now you do!
I created it once and added it to the hub. Found out half a year later that Hans made a similar custom transformer. So I had to put them to the test. If Hans's would outperform mine, I would have removed mine from the Hub, but that wasn't the case.
  • Aug 20, 2019 3:38 PM UTC
Now you do!
Haha, sounds like a challenge to Hans ;-) @redgeographics
Forum|alt.badge.img+63
It's not like I'm short on challenges lately ;)
itsmatt
  • Aug 20, 2019 3:48 PM UTC
Oh yeah, this works a treat. Works in BulkMode too. Nice one Lars
lars_de_vries
You're welcome!
jacklonsdale
  • Aug 21, 2019 7:17 AM UTC
This seems like a good solution, but does the WorkspaceRunner need quotation marks and comma separators between filenames? I've tried with and without and I just get warnings and it doesn't run.
jacklonsdale
  • Aug 21, 2019 7:18 AM UTC
Hi David, works perfectly, thanks for the solution!
gio
Forum|alt.badge.img+15
  • Aug 21, 2019 3:47 PM UTC
it's as simple as
@ceil(@div(@Value(some_value),@Value(some_modulus)),0))
or floor or combine div, fmod
All can create groups based on some modulus.
And require only 1 line in a tester or attrobutecreator or..
