workspacerunner
  • Sep 23, 2015 6:28 AM UTC
  • 153 views
I create a MapInfo to CSV just to get a feel of how to use FME WorkspaceRunner, I tried to imitate the example:
https://knowledge.safe.com/articles/Samples_and_Demos/WorkspaceRunner#toc1
which was provided in the Documentation however I am quite wondering how it works.
I have 30 mapinfo files (on my target application could be 20k++ files)
so when I run the normal mapinfo to csv
it goes normally as below:
however, when I run using the workspace runner, I get 4 times the number of files i had previously. why is this so?
thanks in Advance.
kind regards,
Jubert
  • Sep 23, 2015 6:56 AM UTC
Hi Jubert,
Two comments.
1. One MapInfo (TAB) data usually consists of 4 files. i.e. *.tab, *.dat, *.id, *.map. I think it is the reason that the number of features read by the PATH reader was 4 times of the number of source data. Try setting "*.tab" to the Path Filter parameter of the reader.
2. The source file path will be contained by "path_windows" and "path_unix" attributes of the feature coming from the PATH reader. To pass the file path to the SourceDataset_MAPINFO parameter of the child workspace, you will have to set "path_windows" attribute to the parameter in the WorkspaceRunner.
Hope this helps.
Takashi
  • Sep 23, 2015 7:13 AM UTC
You can set the Path Filter parameter in the Navigator window.
  • Sep 23, 2015 7:19 AM UTC
Hi Takashi,
Thanks so much for your quick response. That Worked well for me!
1. When changed the Path Filter and it read only 30 files. although I noticed that it also created 30 output files already before the full run was complete. so if I have 20k++ small mapinfo tab files...it would create a massive number of results and am not sure if its caching it before it provides a result.
2.  However, When I changed WorkspaceRunner "source files" to path_windows... it writes the results along after it finishes the workspace process.
It is a bit clearer now, thanks so much Takashi
kind regards,
Jubert
