What software or extension do I need for connectin gfrom FME 64 bit to ArcFM 10.6.1a GeoDatabase (ESRI version 10.6.1) running on Oracle 19c? We know the 32 bit FME can connect with ArcFM using the Object Reader library but couldn't get 64 bit FME to
  • January 28, 2021
  • 87 views
What software or extension do I need for connectin gfrom FME 64 bit to ArcFM 10.6.1a GeoDatabase (ESRI version 10.6.1) running on Oracle 19c? We know the 32 bit FME can connect with ArcFM using the Object Reader library but couldn't get 64 bit FME to conn
  • January 28, 2021
@captonssj​  Notes on FME and Esri Versions and Compatibility and Reading ArcFM Geodatabase data using FME should help answer this question. In summary, you need to contact Schneider Electric to get the 64bit ArcFM Object Reader and also install the ArcGIS 64bit Geoprocessing.
tomf
Forum|alt.badge.img+31
  • January 29, 2021
You'll also need a 64-bit Oracle client too!
