What is acceptable for FME Augemented Reality Writer?
  • Apr 19, 2018 6:46 PM UTC
  • 72 views
bozewolf
I'm trying to visualize a scene using the FME Augmented Reality (AR) writer.
As an Input I have a point cloud, and have shifted the origin with Offsetter. I used a PointCloudSurfaceBuilder to get a 3d object in the scene.
The resulting model is full of holes, and the color attribute is not preservered, and although crude the model is with holes.
I would like to know if some have had more succes and have been able to add the color information to the model?
Best answer by redgeographics
If you generate a surface from the point cloud it should at least get rid of the holes. For the color you could rasterize the color info from the point cloud and drape that over the surface.
danilo_fme
Forum|alt.badge.img+58
  • Apr 19, 2018 7:16 PM UTC
Hi @grootstebozewol,
You can see this link : Export to fmear
Thanks,
Danilo
Forum|alt.badge.img+63
