What could be going wrong? File Geodatabase Error
  • May 4, 2018 4:47 PM UTC
  • 81 views
I keep getting this when trying to write to an ESRI FGDB: "Unable to remove existing dataset at location `.......' for writer `GEODATABASE_FILE_1'.
Any suggestions?
There was a lock on the FGDB which was moved but then I get this when run:
"Translation FAILED.
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "c:\\program files (x86)\\arcgis\\desktop10.5\\arcpy\\arcpy\\__init__.py", line 22, in <module>
from arcpy.geoprocessing import gp
File "c:\\program files (x86)\\arcgis\\desktop10.5\\arcpy\\arcpy\\geoprocessing\\__init__.py", line 14, in <module>
from _base import *
File "c:\\program files (x86)\\arcgis\\desktop10.5\\arcpy\\arcpy\\geoprocessing\\_base.py", line 14, in <module>
import arcgisscripting
ImportError: No module named arcgisscripting"
debbiatsafe
Forum|alt.badge.img+24
from _base import *
Hi @charlesbanks
Can you change the Python Compatibility parameter of your workspace to the ESRI ArcGIS Desktop (2.7) and rerun your workspace? Does the error still appear?
debbiatsafe
Hi @charlesbanks
DebbiAtSafe, Thanks. That worked.
