User Parameters from file
  • Jul 14, 2014 11:23 AM UTC
  • 9 replies
  • 225 views
Hello,
Is it possible to read user parameters from a text/xml file. I need to store user parameters in a file which it turn read by a workbench to set a connection info which will be used to connect to db.
Regards,
  • Jul 14, 2014 1:15 PM UTC
Hi John,
1. WorkspaceRunner approach
Create another workspace. It reads parameter values from the text/xml file, and passes them to the main workspace through a WorkspaceRunner.
2. Scripted parameter approach
If the number of required parameter is just 1, define a scripted parameter which reads a parameter value from the file and returns the value, and then link the db connection parameter to the scripted parameter.
Otherwise, it'll be a little complicated as the followings.
1) Define a scripted Tcl parameter (e.g. PARAM1).
The script reads parameter values from the text file, puts them other than the first one as macros, and returns the first one.
puts {MACRO __PARAM2 $value2}
puts {MACRO __PARAM3 $value3}
return $value1
Scripted Tcl parameter can set macros at run-time. Python cannot do it.
Tcl xml package seems not to be installed in standard FME installation, so it's difficult to read parameter values from an XML document.
2) Define multiple scripted parameters to fetch and return the macro values seperately.
PARAM2
return $FME_MacroValues(__PARAM2)
PARAM3
return $FME_MacroValues(__PARAM3)
3) Link the DB connection parameters to the scripted parameters (PARAM1, PARAM2, PARAM3 ...).
Takashi
  • Jul 15, 2014 4:35 AM UTC
Thanks Takashi.
First approach is out of question as I have to publish it on FME server.
I will be having 3 parameter username, pwd and db_instance.  I am going for scripted param approach. But I'm no expert on TCL at all (hardly ever used it) So it would be great if you could take a look at a script I created and let me know where I am going wrong ot is there any better way do it.
set infile [open "/tmp/anyFile.txt" r]
while {![eof $infile]} {
set part [split [gets $infile] " "]
set props([string trimright [lindex $part 0]]) [string trimleft [lindex $part 1]]
close $infile
set pwd $props(USERNAME)  #This is not working
set inst $props(INSTANCE)      #This is not working
#assign to macro. These will be used in other params
puts {MACRO __PARAM2 $pwd}
puts {MACRO __PARAM3 $inst}
return $props(PASSWORD) #this works
John
  • Jul 15, 2014 6:08 AM UTC
How are the parameters written in the file?
Line by line?
username
password
instance
or all in one line?
username password instance
  • Jul 15, 2014 8:56 AM UTC
File is in the format
INSTANCE MYINSTANCE
USERNAME SCOTT
PASSWORD TIGER
john
  • Jul 15, 2014 9:54 AM UTC
Thanks Takashi. It's working.
  • Jul 15, 2014 1:03 PM UTC
Good to hear it works.
Regarding this part:
If you intend to resolve multiple spaces between tag and value using "string trim***" command, I think unexpected result could occur.
"split" command doesn't collapse consecutive white spaces. So if the input line is "USRENAME<space><space><space>MYNAME", the result would be:
part 0 = USERNAME
part 1 = <empty>
part 2 = <empty>
part 3 = MYNAME
When multiple spaces can occur between tag and value, a workaround is:
set part [split [string trim [gets $infile]]]
set props([lindex $part 0]) [lindex $part [expr [llength $part] - 1]]
Alternatively, you can also use "regexp" command. For example:
regexp {([^\\s]+)\\s+([^\\s]+)} [gets $infile] m tag value
set props($tag) $value
FYI.
  • Jul 15, 2014 1:31 PM UTC
This is also available.
set props([lindex $part 0]) [lindex $part end]
mark
  • Jul 15, 2014 9:13 PM UTC
This is under consideration already, so I will add the details of this thread so you are informed if and when it is implemented. It is targeted for FME2015, so we may be lucky and this is done sooner rather than later.
For your info, the reference number is PR#38675. If you contact support about this issue be sure to mention this PR number.
Regards
Mark
Mark Ireland
Product Evangelist
Safe Software Inc
  • Jul 16, 2014 12:03 AM UTC
Hi Mark,
Do you perhaps consider new parameter type that can read an external file to configure the parameter value at run-time?
If so, that's great!
Takashi
