Update File Geodatabase
  • Nov 25, 2014 6:52 PM UTC
  • 75 views
I have a file geodatabase that i need to update weekly with a CAD file. How i can set up the update on the file geodatabase? I am using Esri Geodatabase (File Geodb ArcObjects)
Thank you,
David
  • Nov 26, 2014 7:58 AM UTC
look at this article: http://fmepedia.safe.com/articles/Samples_and_Demos/Updating-Inserting-and-Deleting-features-in-an-unversioned-Geodatabase
The principle for updating is the same as for deleting.
You can also consider using the DatabaseUpdater (http://docs.safe.com/fme/html/FME_Transformers/Default.htm#Transformers/databaseupdater.htm%3FTocPath%3DFME%20Transformers%7CDatabase%7C_____3). It does the same thing, but with a different GUI, and might be a bit more intuitive.
David
Hi David,
I am using the  SQL Statement To Execute Before Trasnlation.
delete  from ROOMS
where BLDGFL=$(EnterBLDGFL)
$(EnterBLDGFL) = variable enter by the user.
I get this error. Error executing SQL: 'The table was not found.'
The table is there. I switch from file GDB to Personal GBD.
  • Nov 27, 2014 7:47 AM UTC
look at the first link I posted, that works fine for File Geodatabases. Set the writer in DELETE mode and set the table primary key (probably BLDGFL in your case) in the output feature type.
David
  • Nov 27, 2014 7:52 AM UTC
regarding the SQL statement: for a Personal GDB you must use MS Access syntax. That sometimes means you'll have to put square brackets around your table and/or field names, e.g.
delete from [ROOMS] where [BLDGFL]='$(EnterBLDGFL)'
Notice how you'll have to put single quotation marks if BLDGFL is a character field.
David
