Unable to convert value taken from Z_ORIGIN keyword to a float data type.
  • Sep 11, 2015 2:00 PM UTC
  • 103 views
Im trying to write a polygon from one polygon to another using FMEs GEODATABASE_SDE writer against a SDE database in SQL Server. Unfortunately Im totally stuck. Everytime i try writing something I get an error saying
This makes totally no sense as I very carefully have removed all posibility traces of anything 3D using both the 2DForcer and in the writers format parameters have anwsered no to if there is any Z values.
Have anyone the slightest idea whats happening ???
  • Sep 11, 2015 2:02 PM UTC
I forogot to mention that I use FME Desktop 2015.1.0.2 32-bit, ArcGIS 10.3.0 and SQL Server 2008 r2. All on the windows plattform...
  • Sep 11, 2015 2:51 PM UTC
Hi
Whenever I get weird errors like this, the first thing I try is to install the very latest version of FME. It has happened many times that the error was due to a bug that's already been fixed.
http://www.safe.com/support/support-resources/fme-downloads/
Is this an option for you? I mention this in particular because the early versions of FME 2015.1.x had some non-obvious bugs.
David
dave29
Forum|alt.badge.img+7
  • Jul 31, 2019 1:23 PM UTC
I had this error come up in FME 2018. I eventually rebuilt the writer and the error went away. This was a point feature class with attachments enabled.
