Triple zipped XML
  • Feb 22, 2015 7:52 PM UTC
  • 109 views
fmelizard
Forum|alt.badge.img+22
Hi ppl,
My input are XML files that are triple zipped (zip in a zip in a zip) I know I can read from a zip file, but is there anyway to read from a triple zipped input?
If not does anybody have a tip on how to handle such a situation? ( any python/ tcl savy's advice?)
Cheers,
Itay
Best answer by takashi
Hi Itay, current FME seems not to have the capability to unzip recursively.
This example is from my old PythonCaller implementation. FYI.
import fmeobjects
import os, re, zipfile
class RecursiveUnzipper(object):
    def input(self, feature):
        def clearDirectory(path):
            if os.path.isdir(path):
                for t in ['%s/%s' % (path, s) for s in os.listdir(path)]:
                    clearDirectory(t)
                os.rmdir(path)
            else:
                os.remove(path)
        # Get zip file path and destinction directory path.
        zipPath = feature.getAttribute('_zip')
        outDir = feature.getAttribute('_out_dir')
        if os.path.exists(zipPath):
            # If specifid output directory exists, remove it beforehand.
            if os.path.exists(outDir):
                clearDirectory(outDir)
            self.index = 0
            self.unzip(feature, zipPath, outDir)
        self.pyoutput(feature)
    # Unzip recursively
    # Extracted file paths will be stored in a list called "_unzipped{}".
    def unzip(self, feature, path, outDir = None):
        if os.path.isfile(path):
            m = re.match(r'^(.+)\\.zip$', path, re.IGNORECASE)
            if m != None:
                zip = zipfile.ZipFile(path)
                if zip.testzip() == None:
                    dir = outDir if outDir else m.group(1)
                    zip.extractall(dir)
                    for t in ['%s/%s' % (dir, s) for s in os.listdir(dir)]:
                        self.unzip(feature, t)
            else:
                feature.setAttribute('_unzipped{%d}' % self.index, path)
                self.index += 1
        elif os.path.isdir(path):
Takashi
  • Feb 23, 2015 6:49 AM UTC
import fmeobjects
                    clearDirectory(t)
                os.rmdir(path)
            else:
                os.remove(path)
            self.index = 0
    # Unzip recursively
            if m != None:
                    zip.extractall(dir)
            else:
                self.index += 1
Takashi
fmelizard
  • Feb 23, 2015 7:33 AM UTC
Hi Takashi,
Fantastic! thanks for your help.
Itay
