Translating oracle dump into ESRI GDB,MDB
  • May 30, 2013 11:47 AM UTC
  • 0 replies
  • 43 views
Hi dear forum users
I want to transfer oracle dump features into one of the ESRI formats. I have a spatial Building table which have nearly 1.5m features inside.Here is the symptoms:
 1) I am using Data interop extension on Arcmap 10. When i try them convert from ETL spatial tool; it waits too much when calculating intersections. Plus that; some of the string column records does not even loaded.
2) In order to see the string features i follow a way like that:
   First i translate dump features into ArcInfo coverage. Then i create a feature class as the schema type in oracle and load all the data from coverage file. Is there a direct connection method?
3) quick export gives an error in the log file.
Thank you all.
