Transform a 2D autocad file (dwg) to CityGML
  • Sep 26, 2015 7:34 PM UTC
  • 78 views
Hello,
I am trying to create a workflow in order to transform a dwg to a cityGML file and later to import it into a 3D citygml database.
I have tried to find an example online doing something similar but I had no luck.
I wanted to ask if something like this is possible with FME and if there is an available example to get a first impression of how to implement it.
Thanks.
Dimitris
  • Sep 28, 2015 10:34 AM UTC
  • Sep 28, 2015 6:34 PM UTC
So if I understand correctly what I have to do is transform my 2D dwg file to IFC (spaces) like here: https://knowledge.safe.com/articles/How_To/AutoCAD-to-IFC-Conversion-Example And then use the workflow described in the link you send me in order to transform the IFC to cityGML. Does the above makes logic? Or the middle step of "transforming the 2d dwg to IFC" is an overkill and I can by pass it?
