TopologyBuilder problem
  • Oct 26, 2015 1:33 PM UTC
  • 82 views
I have a line shapefile and a nodes shapefile, I want to via the topologybuilder to get the from_node_ and to_node_. However, after this transformer, I got some extra nodes which are overlapped on the some input nodes. Those are not I wanted. Because I saw that by an intersection point of 3 lines, 2 lines have the same to_node_, but another has a different to_node_, which is overlapped.
How can I solve this problem? (I can send the data and script)
Thanks for helping!
Best answer by jdh
It sounds like your lines might have slight offsets.  Try using a snapper prior to the TopologyBuilder.
jdh
Forum|alt.badge.img+41
  • Oct 26, 2015 1:57 PM UTC
  • Oct 26, 2015 3:17 PM UTC
Super! Thanks!Snapper solves my problem
