TextStroker ignores fme_rotation
  • Dec 16, 2019 4:41 PM UTC
  • 103 views
Hey FME'ers,
We have a problem with the TextStroker. It seems like it ignores the rotation of our text features.
In attachment an example of our problem.
Note that the textstroker doesn't change the fme_rotation but still the text is shifted 180° around a point different than that of the insertion point.
It seems like the problem started since the update to Version_5. With version_4 there is only a slight shift in position (see attachment). I guess we could set back our textstrokers to version 4 to avoid this problem.
Our FME version: 2019.1.3.0 (20191007 - Build 19642 - WIN64)
we use python 3.6+
Thanks in advance!
Kind Regards,
Louis
Best answer by siennaatsafe
Hello @louisput,
Thank you for reporting this issue to us. I've filed an issue entirely under FMEENGINE-62552 for our developers to take a look. I'll follow up once I've heard back from our developers about this. I do think it's best to keep using version 4 until this is resolved or apply a rotator.
UPDATE Jan 6, 2020: The issue has been fixed as of 2020.0 build 20098
Kind regards,
Sienna
deanhowell
Forum|alt.badge.img+24
  • Dec 19, 2019 1:42 AM UTC
I am finding the same thing, so just monitoring for an answer. We are using FME(R) 2019.1.2.0 (20190829 - Build 19630 - WIN64)
siennaatsafe
Forum|alt.badge.img+12
  • Dec 20, 2019 9:03 PM UTC
Hello @louisput,
Kind regards,
Sienna
