tabular data
  • Nov 11, 2019 12:45 PM UTC
  • 6 replies
  • 82 views
remco
Hello, have a excel sheet with more then 20.000 records and only two columns.
I want to divide the two columns into 7 columns:
The problem now sits in the PART_COLOR, not every row has a color, see my result:
Is there anyone who can help me with this "little" problem?
I will explain what my workflow now is:
StringSearcher: I search for the string "SET NR001" in the Description column. So I only get this value's instead of all the other ones. (about 90 different parts).
AttributeSplitter: split the Description column on every "space" and put them in lists.
AttributeManager: create outputs for every list.
AttributeCreator: create the different outputs for the different inputs, for the "Name" output I use list5 + list6.
Perhaps I am using the wrong tools, but I am a starting user at FME.
Best answer by takashi
Hi @remco, I thinks this workflow does the trick.
Regex:
^(\S+)\s+(\S+)\s+(\S+)(\s+\S+)?\s+(\S+)\s+(.+)$
danilo_fme
Forum|alt.badge.img+58
  • Nov 11, 2019 1:21 PM UTC
Hi @remco
In this case - what do you want to do with these "blank" rows? Add some particular value or not?
Thanks,
Danilo
remco
  • Nov 11, 2019 3:13 PM UTC
Hello @danilo_fme
I want to leave the blank rows blank.
Remco
danilo_fme
  • Nov 11, 2019 3:15 PM UTC
Hello @danilo_fme
Remco
Hi @remco
Thanks you answer - Could you share your Workspace Template ( .fmwt )?
Thanks
danilo_fme
  • Nov 11, 2019 3:27 PM UTC
Hello @danilo_fme
Remco
Hi - Please use this attached file ( Colors Names in Excel ) to compare with your Attribute Part_color - if has the name is true.
I suggest you first to Uppercase all values from Excel ( Colors Names ) before the compare process ( transformer FeatureMerger ).
Thanks, colors.xlsx
Danilo
  • Nov 11, 2019 3:44 PM UTC
Regex:
remco
  • Nov 12, 2019 8:07 AM UTC
Mister @takashi thank you for your answer, that is for me the solution.
@danilo_fme thank you for your help thinking about my problem.
