String Pair replacer not working in FME Server
  • Sep 18, 2021 8:46 PM UTC
  • 5 replies
  • 187 views
Using FME Server 2021.
Uploaded workspace that has no problems to run on Desktop. When running on FME Server it fails with the message:
FAILURE
INCLUDE -- failed to evaluate TCL expression ` FME_CleanseFMEUUID {StringPairReplacer_9f3b9011_1d33_4123_9fa5_4f7dd23e28558} ' -- invalid command name "FME_CleanseFMEUUID" while executing "FME_CleanseFMEUUID {StringPairReplacer_9f3b9011_1d33_4123_9fa5_4f7dd23e28558} "
Best answer by chrisatsafe
Hi @Samuel Engström​ ,
What version of FME Server 2021 are you using? This is a similar problem to what was reported on this post a while back. Fortunately this should be resolve as of build 21571 but if you are using a more recently build than 21571 please let me know so our one of our specialists can look into this.
chrisatsafe
  • Sep 20, 2021 6:14 PM UTC
  • Sep 21, 2021 6:18 AM UTC
Hello,
Thanks for your answer, that is very good to know.
We are using version 21258 that we have plans to update very soon.
  • Mar 2, 2022 7:46 AM UTC
Hi @chrisatsafe​
I'm having the same type of issue:
imageThe difference is that I'm using Data Interoperability extension for ArcGIS desktop build 21627 to create my worbspace.
I have published that workspace as an ETL tool to an ArcGIS server with Data Interoperability for Server extension version 20200407 build 20218. Could the difference in versions be the issue here aas well?
Thanks
chrisatsafe
Hi @chrisatsafe​
Thanks
Yes, same issue as reported above since you are using build 20218. You'll likely need to upgrade to a version with the equivalent of FME build 2021.1+ (equivalent chart here) to have the fix.
  • Mar 3, 2022 10:00 AM UTC
Thanks for the answer Chris and the table. I'll have to see if I can push for an upgrade of our ArcGIS Server from 10.8 to 10.9 to have the newest version of the extension...😬
