store all components to a pointcloud
  • Dec 17, 2018 11:02 AM UTC
  • 128 views
pschout
Forum|alt.badge.img+7
I have a problem with writing components to a pointcloud (.csv) file. I made a workbench that merge 2 pointclouds using the pointcloudmerger. The pointclouds contains depth information of a river and represent 2 different periods. There is partly geographic overlap of the information so a made a merge that results in 3 outputs (merged based on X and Y, not merged and unreferenced), with a pointcloudCombiner the 3 outputs will be combined to 1 pointcloud and a pointcloud writer write the new created pointcloud (.csv). The problem is that in the new pointcloud only a few components (x, y, z and z_last) were stored. The original pointclouds contains a lot more components (depths from every measuring period and more) and I see these components in the data inspector but not in the new created pointcloud, is there a possibility to store the original components also in the new created pointcloud?
The attached picture shows the output of the new created pointcloud and the data as shown in the data inspector.
Best answer by jovitaatsafe
Hi @poppendamme,
I believe you should be able to retain the components by adding them into the Point Cloud Components to Output section in the Point Cloud XYZ writer parameters. You can find this in the Parameters when first adding the writer, or by right-clicking the writer and selecting to edit the writer parameters. I created a fake component to test it out with and got it to work alright.
This is my output in the Inspector:
jovitaatsafe
Forum|alt.badge.img+11
  • Dec 17, 2018 9:35 PM UTC
Hi @poppendamme,
pschout
  • Dec 18, 2018 7:16 AM UTC
Hi @poppendamme,
Thanks for this answer, it works!
