start a work space as soon as a record is added to google sheet
  • Sep 25, 2019 9:40 AM UTC
  • 72 views
boubcher
Forum|alt.badge.img+11
Hello there
is there a way we could trigger a workspace as soon as a record is added to google sheet
Thanks
Best answer by david_r
Have a look at the Google Sheet API and see if there are any REST triggers that can be configured. You could then look into having those notify an FME Server topic which is connected to a workspace.
A simpler (but less efficient) solution would be to poll the google sheet every x minutes and check for changes.
  • Sep 25, 2019 9:48 AM UTC
itay
Forum|alt.badge.img+19
  • Sep 25, 2019 11:23 AM UTC
If the API doesnt provide the solution you should check https://zapier.com/app/dashboard
for possible integration, I am using Zapier it to trigger a topic on FME Cloud and it works like a charm.
boubcher
  • Sep 26, 2019 7:18 PM UTC
@itay
yes the Zapier work well, but we were looking for another way to do it , using the google sheet trigger
for a ref : https://developers.google.com/apps-script/guides/triggers/installable
Thanks again guys for your help
