SQLExecutor:_'select st_srid(geom)' gives wrong result
  • May 5, 2018 1:06 PM UTC
  • 69 views
dollargis
When I run the statement 'select st_srid(geom) as epsg from my.table' on the psql command prompt, it correctly returns 31468
When I do the same in the SQLExecutor transformer, in returns 0.
Doing the same exercise with 'select count(*) as my_counter', the results are identical.
What is wrong here? The docs?
fmelizard
Forum|alt.badge.img+22
  • May 7, 2018 10:34 PM UTC
Hi @dollargis, does the query work for other tables?
steveatsafe
Forum|alt.badge.img+16
Hi @dollargis,
Both the SQLCreator and SQLExecutor seem to work for me in FME 2018.
What version of FME are you using?
dollargis
  • May 8, 2018 3:51 PM UTC
Sorry, my fault - I got confused with the huge number of tables and selected one for the test which indeed had no projection set
