SIGRID format
  • Nov 19, 2013 9:41 AM UTC
  • 40 views
Has anyone come across the older SIGRID format or know of any tools or off the shelf file readers?  http://nsidc.org/data/docs/daac/nsidc0050_aari_seaice/sigrid.html
Thanks,
Annette
  • Nov 19, 2013 9:52 AM UTC
I have never seen or heard about SIGRID support for FME, hopefully someone else can chime in if they've got any experience with it.
That being said, I think it could be a very good candidate for a custom format implemented e.g. using the PythonCreator.
Have a look at the example I posted here that uses a PythonCaller to parse a CSV file into FME features. It should give you an idea how it could be done.
David
sigtill
Forum|alt.badge.img+25
  • Nov 19, 2013 1:32 PM UTC
Hi Annette!
I see there are 2 example-files on the site you mention. As David mentions it is possible to create a custom format to handle this. If you contact me at sigher (AT) norkart.no with a small example-file I can see if we already have some reader available for this format through some other in-house software.
Sigbjørn
Norkart - Trondheim - Norway
