shp to dwg area,SD30 Area to shp polygon settings
  • Jun 8, 2017 2:23 PM UTC
  • 79 views
The area did not exist in the dwg-File, which parametres Needs the dwg polygon. In the DATA_Inspector out of des Workbench it Looks so:
Which Settings are Missing for the Export to dwg?
to convert an area to dwg the area did nor exist. By Output in Dataexpector the Area are there. AutoCAD_entity=autocad_mypolygon
Die Flächen werden nicht in im DWG gespeichert, bei der Ausgabe der Workbench in einen Datainspector werden diese angezeigt:
autocad_entity (encoded: utf-8)= autocad_mpolygon
autocad_mpolygon_object_type (encoded: utf-8)=0
autocad_mpolygon_pattern_name (encoded: utf-8)=1
autocad_with (64 bit integer)=2
Für Hilfe wäre ich dankbar
mygis
Forum|alt.badge.img+14
  • Jun 9, 2017 6:25 AM UTC
Hi @dirk1964, would you be able to share your workspace?
Thanks
gio
Forum|alt.badge.img+15
  • Jun 9, 2017 10:23 AM UTC
@dirk1964
If the inspector shows it, it is in the dwg.
This might be due to corruption of dwg. (see forum for how this can happen).
Often a purge will help.
If not, just copy the autocad_identity_id from the inspector and use a search in autocad. The object will be selected even if you can't see it. Then you can delete it (if that is what you wish to do).
There is a very old forum on this same object, user Kamal had this issue. It was solved by the above mentioned suggestion.
