Setup Oracle Client For FME2017
  • Sep 7, 2018 2:39 PM UTC
  • 97 views
Bonjour,
j'ai bien lu l'article "How to setup an Oracle Instant Client for use with FME" mais la version 2017 de FME ne trouve pas le client Oracle alors que la 2014 toujours installé trouve bien le client Oracle.
Que dois je faire ?
Par ailleurs, le client Oracle fonctionne très bien avec d'autres logiciels.
Merci
Hello,
I read the article "How to setup an Oracle Instant Client for use with FME" but the 2017 version of FME does not find the Oracle client while the 2014 still installed finds the Oracle client. What should I do ? In addition, the Oracle client works very well with other software. Thank you
  • Sep 7, 2018 9:46 PM UTC
Are FME 2014 and FME 2017 both 32 bit or 64 bit? The Oracle client must be installed as the same as FME. Of course it is possible to have both 32 and 64 bit FME but you have to have 32 and 64 bit Oracle client also.
steveatsafe
Forum|alt.badge.img+16
@gilles_gautier, I would agree, the cause is likely as @mark_1spatial indicates. Let us know if you get this resolved!
