Set the Writer to output to the same folder as the Reader source
  • Apr 7, 2017 3:14 PM UTC
  • 88 views
I am trying to set the Writer Destination folder to dynamically or automatically set to the location of the Reader Source folder but I am not having much luck.
I thought the easiest approach would be to use the FilenamePartExtractor and set the _dirpath as the attribute value or user parameter of the Destination folder but it doesn't work.
Does anyone know the best way to set these parameters in FME?
Thanks
Andrew
erik_jan
Forum|alt.badge.img+26
  • Apr 7, 2017 3:38 PM UTC
I think you will need a combination or the mentioned FilenamePartExtractor and the Dataset Fanout, which you can find in the Writer parameters in the Navigator Window.
