Select statement using File Geodb Open API.
  • Oct 4, 2017 8:02 AM UTC
  • 66 views
nielsgerrits
Forum|alt.badge.img+67
I think no but just to be sure: Is it possible to use a select statement on a geodatabase using the File Geodb Open API reader? I know the tooltip, just double checking with the community before going another route...
  • Oct 4, 2017 8:15 AM UTC
Interestingly, a where-clause is actually supported in the regular reader:
But I was unable to find similar possibilities in the FeatureReader. Would be interesting to hear from Safe if the difference is intended.
nielsgerrits
Freaking great! And it works like it should! Now I only have to find a way to dynamically fill the where clause without having to use a WorkspaceRunner... Thanks for this quick reply, I should test and try the old readers more often before posting.
  • Oct 4, 2017 8:42 AM UTC
Soulds like an idea for where-clause support in the FeatureReader is in order
  • Oct 4, 2017 8:46 AM UTC
Vote here for the idea to add where-clause support for the FILEGDB format in the FeatureReader:
https://knowledge.safe.com/idea/54714/featurereader-and-filegdb-with-where-clause.html
